American CLASSIC Car | Detailing 1966 Ford Mustang
Detailing a 1966 Ford Mustang can be a rewarding process that enhances the car's appearance and preserves its classic charm. Here's a step-by-step guide to detailing a '66 Mustang:
**1. Wash the Exterior:**
- Start by rinsing the car with water to remove loose dirt and debris.
- Use a gentle automotive soap and a soft sponge or microfiber wash mitt to wash the exterior, working from top to bottom.
- Rinse thoroughly to remove all soap residue.
**2. Clean the Wheels and Tires:**
- Use a dedicated wheel cleaner and a brush to clean the wheels, removing brake dust and grime.
- Scrub the tires with a tire brush and tire cleaner to remove dirt and restore their black appearance.
**3. Dry the Car:**
- Use a clean microfiber towel to dry the car thoroughly, starting from the top and working your way down.
**4. Clay Bar Treatment:**
- Use a clay bar kit to remove embedded contaminants from the paint surface, such as tar, sap, or industrial fallout.
- Spray a lubricant onto the surface and gently rub the clay bar back and forth, working in small sections.
- Wipe away any residue with a clean microfiber towel.
**5. Polish and Wax:**
- Apply a polish to the paint surface using a dual-action polisher or by hand to remove fine scratches and restore shine.
- Follow up with a high-quality carnauba wax to protect the paint and enhance its depth and gloss.
**6. Clean and Condition the Interior:**
- Vacuum the interior to remove dirt and debris from carpets, seats, and floor mats.
- Use a mild interior cleaner and a soft brush to clean surfaces such as the dashboard, door panels, and center console.
- Condition leather or vinyl surfaces with a suitable product to restore moisture and prevent cracking.
**7. Detail the Engine Bay:**
- Cover sensitive components such as the distributor, alternator, and carburetor with plastic bags or aluminum foil.
- Use a degreaser and a brush to clean engine surfaces, being careful not to soak electrical components.
- Rinse thoroughly with water and dry with a clean towel.
**8. Clean Glass and Chrome:**
- Use a glass cleaner and a clean microfiber towel to clean the windows, both inside and out.
- Polish chrome trim with a chrome cleaner or metal polish to remove oxidation and restore shine.
**9. Final Touches:**
- Use detailing spray to remove any remaining fingerprints or smudges on the paint surface.
- Use a microfiber towel to buff the paint to a high shine.
**10. Protect and Maintain:**
- Consider applying a paint sealant or ceramic coating to provide long-lasting protection against the elements.
- Regularly wash and maintain the car to preserve its appearance and protect your investment.
By following these steps, you can achieve a showroom-quality finish and keep your 1966 Ford Mustang looking its best for years to come.
