Greg Warner’s Bad-Blown 565ci ’69 Chevelle Insane 200ft Wheelstand!
If you’re a fan of muscle cars, then you’ve probably heard of Greg Warner’s Bad-Blown 565ci ’69 Chevelle. This Midwest Super Stock Mafia member has taken his Chevelle to the extreme, pulling off an insane 200-foot wheelstand at the Byron Wheelstand Weekend. Let’s take a closer look at what makes this car so special and how Greg pulled off this incredible feat.
First off, let’s talk about the engine. The Bad-Blown 565ci engine is a true beast, packing in over 1,000 horsepower thanks to its supercharger and custom-built components. This engine is capable of pushing the Chevelle to incredible speeds, but it’s also what allows Greg to pull off such a massive wheelstand. With so much power under the hood, it’s no wonder this car can lift its front wheels off the ground and keep going.
But it’s not just the engine that makes this car special. Greg has put countless hours of work into his ’69 Chevelle, customizing it to fit his specific needs as a racer. He’s made modifications to the suspension, steering, and other components to ensure that the car can handle the extreme stresses of a wheelstand. He’s also added safety features like a roll cage and racing harness to protect himself in case of an accident.
So how did Greg manage to pull off such an insane wheelstand? It takes a combination of skill, experience, and a bit of luck. Greg had to carefully control the throttle and steering to keep the car pointed straight during the wheelstand, all while ensuring that the engine didn’t lose power and cause the car to come crashing down. He’s been practicing to perfect his technique for years, and it paid off at the Byron Wheelstand Weekend.
In conclusion, Greg Warner’s Bad-Blown 565ci ’69 Chevelle is a true marvel of engineering and racing skill. It takes a lot of hard work and dedication to build a car like this and even more to pull off a 200-foot wheelstand. If you’re a fan of muscle cars, then you definitely don’t want to miss out on seeing this car in action.
